You are here: FME Server Administrator's Guide > Licensing > Install a Separate License Server
A FME floating license allows a networked license server to provide FME floating licenses to multiple FME users on a network.
You can use the floating license capability for all FME editions, and a single license server can serve different FME licenses. For example, if a site requires floating licenses for both FME Base Edition and FME Server Edition, you can serve both licenses from one floating license server.
Note:  The preceding paragraph does not apply to floating licenses with different expiry dates.
If you need to transfer an existing floating license server to a different computer, install the floating license server on the new computer first, and then request a new license file from Safe Software.
In this Section
